Schleprock Posted November 18, 2020 Report Share Posted November 18, 2020 I've got a 2019 Sundance Marin 880 that's tripping GFCI after about 5 minutes of operation after powerup. Image of the associated error message is below. Recently replaced a temperature sensor that was reading wrong, and causing OverHeat errors. That replacement went well, and the sensor reads accurately to the panel display now. Suspecting that this may not be the heater, as the GFCI trip occurs after a few minutes of normal heater operation. Any suggestions? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 18, 2020 Report Share Posted November 18, 2020 Remove the filters until the issue is fixed. Dirty filters can slow the flow of water through the heater causing the water to boil or over heat in seconds. Could be flow related is the circ pump running do you see water moving in the foot well? 6 hours ago, Schleprock said: GFCI trip occurs after a few minutes of normal heater operation. Disconnect the heater from the board. It usually takes a few minutes after power up for the heater to test fire. If the heater is bad then that is when the breaker will trip. Test the heater for continuity. Check all pumps for seal leaks. If you have a leaking pump seal...the pump starts up and might run for a few minutes and then sucks water into the pump/motor housing and then trips the breaker. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted November 19, 2020 Report Share Posted November 19, 2020 Disconnect the ozonator. 1 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 19, 2020 Report Share Posted November 19, 2020 But first disconnect the ozontor...lol 1 Quote Link to comment Share on other sites More sharing options...
Chevelleskick Posted October 25, 2021 Report Share Posted October 25, 2021 Please was this ever fixed. I am having the same exact problem Quote Link to comment Share on other sites More sharing options...
Chevelleskick Posted October 25, 2021 Report Share Posted October 25, 2021 I am getting desperate lol. I had a hot tub technician come out and tell me it was just my temp sensor and it clearly was not $250 down the drain Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 27, 2021 Report Share Posted October 27, 2021 On 10/25/2021 at 12:31 PM, Chevelleskick said: I am getting desperate lol. I had a hot tub technician come out and tell me it was just my temp sensor and it clearly was not $250 down the drain First, start your own thread and describe your situation. Include pics of equipment area, cir uit board, and wiring diagram. Second, if you paid for a repair and it didn't fix it, call them back. Any ethical business will not charge for a return trip under those circumstances, and should refund at least part of the initial charges, though they will likely charge for whatever it does turn out to be. 1 Quote Link to comment Share on other sites More sharing options...
Awuwi Posted November 29, 2022 Report Share Posted November 29, 2022 I too now have this problem. What was faulty to cause this error? Quote Link to comment Share on other sites More sharing options...
Gspa Posted July 13, 2023 Report Share Posted July 13, 2023 Quote Link to comment Share on other sites More sharing options...
waterbear Posted July 13, 2023 Report Share Posted July 13, 2023 Gspa, thank you for your post but this is a 3 year old thead Quote Link to comment Share on other sites More sharing options...
