ProjectReefBlue Posted November 1, 2020 Report Share Posted November 1, 2020 Hello - looking for assistance converting a 450Gal tub from chlorine to bromine. I have been unable to find sodium bromide up here in Canada to create the initial bromine bank. I do have bromine tablets, floater, and brominating granules (15% bromine / dichlor). What are my best options? I have read conflicting advice on crushing up tablets OR perhaps using the bromine tabs in a floater for a couple weeks while the bank slowly builds up. Looking for input. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted November 1, 2020 Report Share Posted November 1, 2020 2 hours ago, ProjectReefBlue said: Hello - looking for assistance converting a 450Gal tub from chlorine to bromine. I have been unable to find sodium bromide up here in Canada to create the initial bromine bank. I do have bromine tablets, floater, and brominating granules (15% bromine / dichlor). What are my best options? I have read conflicting advice on crushing up tablets OR perhaps using the bromine tabs in a floater for a couple weeks while the bank slowly builds up. Looking for input. Thanks in advance. I don't know of any way to establish a bromide bank without sodium bromide. @Cusser, @waterbear , @dlleno, any advice? Quote Link to comment Share on other sites More sharing options...
ProjectReefBlue Posted November 1, 2020 Author Report Share Posted November 1, 2020 1 hour ago, RDspaguy said: I don't know of any way to establish a bromide bank without sodium bromide. @Cusser, @waterbear , @dlleno, any advice? Not what I wanted to hear - but thank you for the input - its greatly appreciated. Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 8, 2020 Report Share Posted November 8, 2020 If you start using either the tablets or the granular mix you will eventually build up a bromide reserve. Until you do you will have a chlorine spa. I personally would use the granular product since it will most likely be a mix of sodium bromide and a chlorine source. The tablets are an organic form of bromine along with chlorine and will also build up a bromine reserve in the water and crushing and dissolving a few certainly is also a way to go. Either way, just keep your sanitizer at an appropriate level for bromine and let time take care of the transition. It will be invisible to you. So if you want to convert to bromine just stop adding chlorine and start adding your bromine sanitizer. Done deal! Quote Link to comment Share on other sites More sharing options...
ProjectReefBlue Posted November 30, 2020 Author Report Share Posted November 30, 2020 Thank you Waterbear ! The information is much appreciated! Quote Link to comment Share on other sites More sharing options...
JustinTub Posted December 10, 2020 Report Share Posted December 10, 2020 You're right, Sodium Bromide is hard to find in Canada, I had the same struggle with local stores. I got mine online from Pool Supplies Canada. It's on clearance though so I fear they may be discontinuing it https://www.poolsuppliescanada.ca/spa-care-bromide-1-l.html Quote Link to comment Share on other sites More sharing options...
