I have a J-495. Temp set at and reads 98, but actual temp is 106.
Is there an calibration / adjustment I can make without calling a technician to come out?
Thanks, Jim.
Anytime you have an issue with the spa always remove the filters and reset the main power. Take the filters out of the equation. Check your filter cycle duration and make sure it is set to filter no more than 2 hours out of 12 or 4 out of 24. Do you know if the spa has a circulation pump for heating and filtering or does it use one on the main pumps?
