Bonzaizombie Posted October 7, 2020 Report Share Posted October 7, 2020 My hot tub won't go in to high speed for the jets. It works in low but when you press it in high you hear a click then it just stops. Could it be a pressure problem? Its all wired right and everything i know. There are no blown fuses or anything. I replaced my old pump from 2 horse power to 4 horse power. Please help I have racked my brain with it. The pump is a water way pump Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 7, 2020 Report Share Posted October 7, 2020 You probably fried the high speed relay or damaged the pump by installing a pump that has too much power for the plumbing and is consequently overheating the circuit. Or perhaps the voltage is wrong on the new pump. Do you have a multimeter? Test voltage to the high speed pump at the circuit board terminals. Post a pic of the pump, circuit board, and wiring diagram on the inside of the control box cover. Quote Link to comment Share on other sites More sharing options...
Bonzaizombie Posted October 7, 2020 Author Report Share Posted October 7, 2020 I do have one. And I checked the voltage and when it tries to kick on it gets 220 Quote Link to comment Share on other sites More sharing options...
jimmythegreek Posted October 8, 2020 Report Share Posted October 8, 2020 It gets 220 to what terminals in low? Then what terminals in high? Did it ever work or is this the result of the pump swap? 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 8, 2020 Report Share Posted October 8, 2020 22 hours ago, Bonzaizombie said: all wired right and everything i know. Are you sure? Has it worked since you replaced it? Post a pic of the wiring at the pump. If you have voltage at the board then the problem is in the pump or wiring. Quote Link to comment Share on other sites More sharing options...
