GBH Posted September 29, 2020 Report Share Posted September 29, 2020 2020 Envoy, only a month old. The weir gate will open fully when the pumps come on, but will not rise back up when the pumps go off. It will stay down unless you raise it. It stays up once you raise it, but it does not move on its own except when the full jets come on, then it goes down, but as I said it will not rise after the jets are turned off. I have checked and it is in the tracks. It moves easily. Both floats are in place. Not sure why it stopped working. Besides the two small floats, I can't see how the gate works. I am sure I can call the dealer and have it checked out. I just don't want to bother if it something simple that I'm missing. Thoughts? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 29, 2020 Report Share Posted September 29, 2020 Ph. Often a gate will stick in its track due to calcium coming out of solution on surfaces due to high ph/alk. Do you feel a slight sandpaper texture on the spa shell? Quote Link to comment Share on other sites More sharing options...
