CanadianSpaTech Posted September 16, 2020 Report Share Posted September 16, 2020 @jdw1222 every time I click your post "Forbidden" comes up and can't access your post. Quote Link to comment Share on other sites More sharing options...
jdw1222 Posted September 16, 2020 Report Share Posted September 16, 2020 Thanks I am not sure what is happening but every time I post it does that. Was hoping a moderator could fix? here is a copy and paste of what I am trying to post. Have a great lakes spa that got flooded with about 2 of water of so . I replaced the pump and the circuit board and cleaned up the wires Put a new cat6 end on the controller cable. tub started up fine and heated but now the pump never seems to shut off (running on low speed) and to me it seems hotter than the displayed temp. It is flashing an occasional code on the display (IC) , and the jet and light buttons are flashing while running. When display flashes the temp is set to 99 but it is flashing 103 Is there another component or sensor that I missed that maybe was affected by the flood or did i possibly install something incorrectly? I installed a Balboa Water Group Circuit Board VS500 Systems 54369-01, 54369-02, 54369-03 and a Aqua-Flo Flo-Master XP2 06125000-1040 Spa Pump is 2-1/2 HP 230V Dual Speed Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 16, 2020 Report Share Posted September 16, 2020 Post a pic of the board and the wiring diagram on the inside of the box cover. Check your filter cycles. Remove your filter. Quote Link to comment Share on other sites More sharing options...
jdw1222 Posted September 16, 2020 Report Share Posted September 16, 2020 Here is a pic of my board installed. I pretty copied the settings from the board I replaced I’ll have to take a picture of wiring diagram when I get home Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted September 16, 2020 Author Report Share Posted September 16, 2020 What is the filter cycle duration set at? Should be F2...as for the other issues I'm looking at the cat6 wiring next. Disconnect the topside and let it run and see if it runs normal for a few hours...also think it should be moved up to the top plug in for the main controller. Below where it is now is for AUX topside. Check inside cover to confirm Quote Link to comment Share on other sites More sharing options...
jdw1222 Posted September 17, 2020 Report Share Posted September 17, 2020 Here is a pic. I moved the controller cable and tried again. Still flashing the IC code as soon as I start it up (Looks like it is for ice conditions ) the 2 sensors on the heater did go under water. Maybe bad connection there or sensor needs replacing? what triggers the ic code - guessing a sensor ? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted September 17, 2020 Author Report Share Posted September 17, 2020 What topside is in it? Check all the settings in "Switchbank A" Make sure A4 is down and A3 matches your topside. 1 hour ago, jdw1222 said: 2 sensors on the heater did go under water. Should be fine just check to make sure there is a good connection to the circuit board the pins are small and bend easily. Other then that it all looks good to me only other thing I can suggest is to redo the cat6 you worked on. 1 Quote Link to comment Share on other sites More sharing options...
jdw1222 Posted September 17, 2020 Report Share Posted September 17, 2020 It is a fairly new 3 button balboa topside controller Quote Link to comment Share on other sites More sharing options...
jdw1222 Posted September 17, 2020 Report Share Posted September 17, 2020 6 hours ago, CanadianSpaTech said: What topside is in it? Check all the settings in "Switchbank A" Make sure A4 is down and A3 matches your topside. I think this was my issue! I just checked and a4 was up. I moved a4 down and moved a3 up and seems to be working. thanks for the help 1 Quote Link to comment Share on other sites More sharing options...
