Vacuum Keeps Getting Stuck on the Main Drain
Hicks6
10 hours ago, Pool Clown said:
Does your cleaner have a backup valve? That should be taking care of a sticking problem.  If your unit is getting stuck from the suction of the main drain, You probably dont have a VGB drain cover installed, and should do so for safety reasons.
This is true. I have a flat main drain cover. I've looked into this before, but I don't really know how to pick the right retrofit cover for my setup. I suppose I could just bring in the cover to my local pool store.
