PeanutBacon Posted August 23, 2020 Report Share Posted August 23, 2020 Hello, I am wondering if someone could help with this, I recently got a softtub for free which sat around for a couple of years. I first cleaned it and filled it, ran the jets and a lot of this black/green film came flying out of the jets. I’m assuming this is some kind of thing that happens when you leave water sitting in the lines for a while. I did this to clean out the system since I knew this sat around not being used. I drained the soft tub and cleaned everything out with a garden hose and made sure that nothing would be floating around when i turned it on again. so here is my issue, the soft tub will turn on when I plug it in but gives me a P code, the jets will kick on but there is no temperature display on the console, it runs for a minute or two then the temperature comes back on, the tub reached the temperature i needed it to be at and then completely shut off again. I reset the tub and turned it back on again, now it runs for a minute with a P code and then shuts the whole thing off again. I’ve looked into this and the most common response I have is you need to flush the temperature housing. How do I do this? And if I do this or have to replace the thermostat will this fix the issue? 1 Quote Link to comment Share on other sites More sharing options...
shimon b Posted December 26, 2022 Report Share Posted December 26, 2022 Hello. I have the same problem with one year old softub. Did you manage to solve this problem? Thanks Quote Link to comment Share on other sites More sharing options...
torontosofttubber Posted February 6, 2023 Report Share Posted February 6, 2023 ....I have the same issue Quote Link to comment Share on other sites More sharing options...
