I am having trouble getting my spa to fill but, when I turned the pump off it filled up to the jets.  I am not sure what is going on with it. I  have replaced all seals, valves and check valves. I also replaced the pool pump. I just figure out why my spa won't fill up. It has a waterfall that goes into the pool.
Share this post
Link to post
Is there a small pipe with a check valve between the pipes where the valve to switch them is?  I've seen some that don't have that and they just move the valve a little so water goes to the spa too.  Also is your filter reasonably clean?  Also it's possible a small piece of concrete  is blocking the jet that fills the spa.
Share this post
Link to post
