Balboa touch panel, water to hot.
Ndx
Does the spa even have a small circulation pump that is supposed to run 24 hours? Or does it use the main 2 speed pump for filtration and heat? If it uses the main pump duration should be set at 2 hours per 12 hour period 2 times a day = 4 hours out of 24.
  • Thanks 1
@canadianspatech
2 x 2 speed pumps it, uses low speed.
Really I had it running for 24hrs ... For a week :(
Is 4 hours really enough ?
Thank you
Thx, My Manual said at least 8 hours minimum
"Spas with adjustable filter cycles should be operated a minimum of 8 hours a day to remove suspended particles that may exist.( 4 hours per a 12 hour period)"
So lol, I figured 24 hrs will be better :) Hopefully I didn't destroy anything in first week of owning spa lmao!
