Spa Chemical Help
Scubakerny
New to the Spa (Hot Tub) scene, have had pools my whole life but having a hard time keeping the chlorine/bromine levels up. I don't want to over do it but need it to be safe of course. I have to add chlorine daily but ran out, using up the bromine that we got with the spa but would like to move away from that chlorine smell. I am considering two other options to replace the chlorine and bromine. First option is iONRx - https://www.ionrx.com/
Second option is Cleanwater Blue - https://www.spadepot.com/Cleanwater-Blue-Spa-Pro-Supplies-Kit-P2667
Third option is Chlorine or Bromine - If this is the most recommended, what regiment should I be doing......
Thanks for your help
Anthony
The first one is copper based algaecide. Most mineral purifiers for spas use silver ion. Not sure as I have never used copper in a spa.
The second is also a mineral sanitizer system. It is a kit so has what you need with only about half of it being useless. I also do not use liquid minerals, I prefer the cartridge, so can't speak to it's effectiveness.
I should point out that neither of these gets rid of the need for chlorine in your spa. Also, once you add sodium bromide to a spa it will always be a bromine spa until you drain it and start over.
Is it a new spa? Does it have an ozone generator? Have you ever used Ahh-Some spa purge?
  • 3 weeks later...
