What went wrong..
Ndx
Hi Guys,
New Tub - filled with city water.
Tub has ozone and uv
Water was crystal clear, but out of balance.
Went to pool store to test.
Chlorine Total: 0.1, Free: 0.1
TDS 200ppm
PH 8.1
TA 105
Ca 93
Po 2500 ppb
They said to add 140 Grams of TA+
34 grams od pH-
100 grams of TH+ split in 3 doses every 3 hours
59 grams of chlorine
And. 1.28L of Phos Cleanse ( about to add it )
But water turned cloudish no longer crystal clear, should I dump it and start again
Thx
Thx, water cleared up but it seems little foamy, very fine white foam around edge of tub
Here is virgin sample of my city water after whole house filter. ( catalytic carbon )
Free Chlorine 0.08
Total Chlorine 0.08
Combined 0.00
pH 7
Hardness 53 ppm
Alkanity 95
Cyanuric Acid 5 ppm
Phosphate 1943 ppb
@RDspaguy
So the store told me to add ... 59 gms of chlorine to bring it back up... I did so about 3hrs ago... And strips and taylor test of the scale still 10ppm+
I think I will run Ahh Some tomorrow and dump it, and start fresh... Should I skip aqua finesses I guess ?
On 8/6/2020 at 10:43 AM, Ndx said:
Hi Guys,
TDS 200ppm
PH 8.1
TA 105
Ca 93
Po 2500 ppb
34 grams od pH-
NEVER add calcium and baking soda (which is all the TA+ is) at the same time because it will cause calcium carbonate to precipitate out and cloud the water, particualrly with a high pH. Get pH in line first, add the baking soda and wait apprx 24  to 48  hours and retest. If levels are good (60 to 80 for unstablized chlorine, 80 to 100 for stabilized chlorine (but watch your CYA levels!) or bromine. Because of the amount of aeration in spas from the jets there is a tendency for pH to rise because of outgassing of CO2. Running your TA in these lower ranges helps counteract that.
You don't need this! This can also cloud the water, btw!
No, dropping the pH should redissolve some and filtration will remove the rest.
  • Like 1
