C.B. Posted August 6, 2020 Report Share Posted August 6, 2020 I have a Hayward series H millivolt pool heater. When I turn the pump on, water starts to seep out onto the floor. When I am facing the heater it is about half way down on the right side of the unit. Anything in particular that I should be suspecting? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 6, 2020 Report Share Posted August 6, 2020 Manifold gaskets, pressure switch tube, manifold, bypass valve... kinda need to figure it out. @jimmythegreek, any ideas? Quote Link to comment Share on other sites More sharing options...
C.B. Posted August 6, 2020 Author Report Share Posted August 6, 2020 Thanks Jimmy. I have no clue what it could be. Time to call someone in I guess. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 7, 2020 Report Share Posted August 7, 2020 If you aren't comfortable taking it apart yourself it is. You can pull the top off to get in there and poke around. It may be something simple, or not. Quote Link to comment Share on other sites More sharing options...
jack calish Posted August 11, 2020 Report Share Posted August 11, 2020 If the leak is coming from the Hot Tubs tank, you'll need to replace the water heater. Why? Because, most likely, sediment (minerals) has built up at the bottom of the tank, corroding the tank's inner lining. Quote Link to comment Share on other sites More sharing options...
rspar Posted August 20, 2020 Report Share Posted August 20, 2020 Corrosion of the heat exchanger where it meets the manifold is likely which generally means new heater. Though there is a chance it's one of the things RDspaguy said you won't know until you take it apart. Quote Link to comment Share on other sites More sharing options...
