Ndx Posted August 3, 2020 Report Share Posted August 3, 2020 Hi Guys, I just noticed that I get a lot bubbles from one jet but other has very little if any, when I touch it with a finger I can feel flow but no bubbles. Air lock ? Thank you Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 3, 2020 Report Share Posted August 3, 2020 Just one jet out of how many? Which one? Do you have an ozonator? Are there air control valves? Quote Link to comment Share on other sites More sharing options...
Ndx Posted August 3, 2020 Author Report Share Posted August 3, 2020 yes I have AquaNova UV/Ozone.. there are two little vents for it... one is bubbling but other is continous stream, i think according to manual both should have bubbles Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 3, 2020 Report Share Posted August 3, 2020 I'm not familiar with that particular system, but most ozone systems will only have bubbles from one jet. In fact, most split off before the ozone is injected into the pipe. It's a gas being mixed into water, it rises in the pipes and will flow according to the laws of physics. I can't see how you could split the flow of bubbles evenly with the plumbing being used. I am inclined to say it is working as it should. My guess is the bubbles enter the tub low in the footwell and the other "jet" is higher in the tub? That is the typical arrangement. Quote Link to comment Share on other sites More sharing options...
