Tiger River Bengal M Jet switch not working
BWhitens
Kids pushed Jet switch on and off multiple times.  No longer works.  Pushing switch does illuminate the switch panel and display the jets graphic on and off.  The rest of the buttons work as well (temp up/down).  No signs of burnt wires or areas on the circuit board.  The Jet Pump does work...ran power directly to test.  Appears as though the both the switch and the pump are working as they should.  Assuming something with the circuit board.  1999 Tiger River Bengal M.  Any help would be GREATLY appreciated.
Thanks for the response.  I'm betting you're correct.  I wish I knew which piece was the relay, maybe could replace it without removing the entire panel.  Tub is built into an indoor room, a bit tougher to work on since all is below floor/deck level.  Thinking about simply hooking up waterproof external switch up to the jet pump and done with it.  I have a good safe spot on the wall to put a switch.
