In Spa mode only I'm pulling 20 psi. When I put pool and spa I'm pulling 30 psi
skos
It's not surprising. When in spa mode your pump has only the spa suctions to pull from which could restrict flow causing the psi to be lower. I would be a bit concerned that the pump is too much for the plumbing and could be damaged by the lack of sufficient suction flow. It is possible that there is some obstruction blocking the spa suction, perhaps a clogged skimmer or drain cover.
What is the pressure in pool only?
