JayTee Posted July 16, 2020 Report Share Posted July 16, 2020 Howdy! first time on this forum, hope everyone is having a good day. I'm trying to replace the circulation pump in a Balboa EL Neptune (pretty sure that's what its called) Original pump in Hot tub was a Waterway cp-1/15-1n22a 3410020-0E motor The pump motor specs are labeled as follows 1/8 H.P. 230v 0.8A S.F. 1 1725 RPM Continuous run time. Just about every reasonably priced pump ive found (sub $200) is rated at 1/15 H.P. Does it matter? Should I spend ~$300 to get one rated 1/8HP even if the lower HP motor has the same RPM? also the one i keep seeing (Iron Might 3410020-1E) has a lower SF value of 0.63A Is this a big deal? top contender for replacement: https://www.walmart.com/ip/Gecko-Alliance-3410020-1E-Iron-Might-Circ-Pump-44-230V-0-8A/115706139?wmlspartner=wlpa&selectedSellerId=1582&&adid=22222222227046475627&wl0=&wl1=g&wl2=c&wl3=96531595610&wl4=pla-218879689010&wl5=9016858&wl6=&wl7=&wl8=&wl9=pla&wl10=113139572&wl11=online&wl12=115706139&veh=sem&gclid=Cj0KCQjw0rr4BRCtARIsAB0_48Ou_bwsIFM0jSFsDZtfPGZ9KGOZM3lUx4drDR7m_BK6TGXa5vWt9AkaAhUeEALw_wcB Pardon my naivety, first time Hot Tub owner. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 16, 2020 Report Share Posted July 16, 2020 As I said on TFP, they are the same. 1 Quote Link to comment Share on other sites More sharing options...
JayTee Posted July 16, 2020 Author Report Share Posted July 16, 2020 Thank you! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 16, 2020 Report Share Posted July 16, 2020 👍 Quote Link to comment Share on other sites More sharing options...
