Beachcomber Care Free
Just wondering I am on the Beachcomber Carefree chemicals and is it as easy as it sounds just the care free chemicals.  My old hot tub had chlorine disks in the float but is my understanding correct that the care free system chemicals have that and I do not need a floating sanitizer dispenser in it.  I can not seem to find that info anywhere it just says to use care free and care free boost and some soft.  And balaancing the TA, pH and CH.
Is chlorine tablets in a floatie required?
No. Care free boost is a type of chlorine. The other stuff is combo chemicals, which I am not a fan of personally. If you are having trouble I suggest you read the sticky thread at the start of the spa chemistry forum about the dichlor/bleach method, do a little research on basic water maintenance, and ask specific questions. I doubt anyone on this forum would recommend what you are using.
