80s spa
213
If anyone can help it would be much appreciated! I just bought a house with an old 80s spa in it and have had a few problems with getting it to run. I had to first get an electrician to replace the power point because ants had lived in it for years and then ive had a problem getting the pump to run. The heating unit works but i was wondering what would the best replacement pump be for this spa? Ive attached some photos -
I have no idea. Here in the US they are pretty rare. I have only seen a handful in 25 years.
The wet end is the part of the pump assembly that gets wet, meaning has water moving through it and pipes connected. The other part is the electric motor.
Shouldn't take a lot to replumb it for whatever pump you get. Just need unions to fit the new pump and some pvc fittings, pipe, and glue.
