1996 Sunrise 799
north
I recently bought a new house that came with a hot tub. It was installed in 1996 and is a Sunrise 799. Before I fill it up, I want to be absolutely sure that I know how to drain it afterwards. The owner's manual states that it comes with a drain valve that connects to a garden hose, but I cannot for the life of me find such a thing anywhere. Any help?
Post some pics of the equipment area, paperwork doesn't help us see it. It is probably a small hose coming off of the pipes near the pump and could be stuck back in a corner or have the connection on the bottom edge somewhere. It may have been removed, as they are a common leak issue.
I use this.
https://www.spadepot.com/Shake-a-Vac-II-Spa-Pool-Water-Vacuum-Drain-P850
  • Like 2
As RDSpaGuy said - don't bother with the drain on the tub - these can cause leaks over time.  It's easier to simply use a long hose and pull it over the side of the tub.  As long as your tub isn't the lowest spot in your yard, you'll have no problem draining the tub with gravity alone
If you have a long hose, it's super simple to do without anything extra - https://www.hunker.com/12002448/how-to-drain-a-hot-tub-with-a-hose
  • Like 2
I usually tell folks to have the one end lower than the spa and with the spa still running place the other end over a jet until you have water coming out the far end and then just drop the spa end down into the foot well and turn of the power to the spa.
  • Like 2
I use this.
Thanks. Wasn't sure what was important to see so I took pictures of everything.
Look around the very bottom edge on the outside of the spa for a hose connection. It is often at a corner near the equipment, sometimes recessed under the rounded corner cabinet. They are infrequently used and often break when fiddled with, so I would still recommend the link I posted or the hose trick suggested. Or even a cheap sump pump.
Of course, disconnecting any of the threaded union connections at the pump or heater will dump it fast but will get the equipment wet.
  • 2 years later...
