Jandy aqua pure “no flow”
I just had a new salt cell and sensor installed but there is a “no flow” message and no lights are on for the cell on, resting, or reversing.
what can I do since it’s the weekend and there is almost no chlorine in the pool now.
Link to post
Well, you either have low flow through the cell, it is installed backward, or a bad flow switch in the cell. Check the waterflow direction arrow on the cell. Clean your filter, pump basket, and skimmer. If you have a multiport valve put it in bypass to test. Check for debris in the pump impeller.
Link to post
