DBB Posted June 27, 2020 Report Share Posted June 27, 2020 I just had a new salt cell and sensor installed but there is a “no flow” message and no lights are on for the cell on, resting, or reversing. what can I do since it’s the weekend and there is almost no chlorine in the pool now. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 27, 2020 Report Share Posted June 27, 2020 Well, you either have low flow through the cell, it is installed backward, or a bad flow switch in the cell. Check the waterflow direction arrow on the cell. Clean your filter, pump basket, and skimmer. If you have a multiport valve put it in bypass to test. Check for debris in the pump impeller. Quote Link to comment Share on other sites More sharing options...
DBB Posted June 29, 2020 Author Report Share Posted June 29, 2020 Thx so much .Where is the water flow direction arrow? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 29, 2020 Report Share Posted June 29, 2020 It should be molded in to the plastic housing somewhere. I am not familiar with that specific brand. https://www.manualslib.com/manual/602018/Jandy-Aquapure-Apure700.html?page=9#manual Quote Link to comment Share on other sites More sharing options...
