Etay Posted June 24, 2020 Report Share Posted June 24, 2020 Hi, I have a 20 year old hot tub that has original pumps and a blower. They all work!! Recently, the blower motor started making noises while it ran and it was full of water. It tripped the breaker. My question is why is this happening all of a sudden now? The blower still works, always starts normally then a few seconds later it makes that weird noise with the water. Can I fix this somehow? Thank you for your assistance! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 24, 2020 Report Share Posted June 24, 2020 Yes, you can fix it. What brand is it? Blowers are protected from water by a hartford loop under the spa shoulder and a check valve. Check valves fail, and a high water level from overfill or multiple bathers can overflow the loop. In some cases the loop itself can drop over time from loss of support. A new check valve will solve the issue, but if the loop has dropped it should be addressed. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.spadepot.com/Blower-Check-Valve-14-152-P711C725.aspx&ved=2ahUKEwint9Le5JnqAhWNKM0KHb-_B94QFjAAegQIBhAB&usg=AOvVaw10CCtKeXXuJ1sGj7Hc1Otu Quote Link to comment Share on other sites More sharing options...
Etay Posted July 6, 2020 Author Report Share Posted July 6, 2020 Thank you for the reply! I will replace the blower and install a new check valve. When I cut the pipe to replace will it pour out water? Or is it just residual water in the pipe? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 7, 2020 Report Share Posted July 7, 2020 Just residual. Quote Link to comment Share on other sites More sharing options...
