jimmythegreek Posted June 23, 2020 Report Share Posted June 23, 2020 I have a new to me limelight flair. Great shape overall it's a pearl color shell. Looks like the previous owner had no lifter and the mesh under cover scratched up the topside. Not bad but you can see it in certain lighting conditions with sun etc. Its got 2 small sections that are more than swirls. I read polishing compound for cars works. I have experience detailing I was just wondering if someone has done this before and looking for a product recommendation. Most stuff I see is just wipe on waxy stuff. I need something a little more aggressive for the 2 spots Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 23, 2020 Report Share Posted June 23, 2020 Acrylic clearcoat. Good as new. I don't refinish cars, so couldn't say what is used for that, but it would probably be ok as well. Avoid wax and polish unless you like waxing and polishing. Fancy bumping into you here. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 23, 2020 Report Share Posted June 23, 2020 Sounds like crazing and see it often. How to (never tried it but seems simple enough. If you try it take before and after photos and post please). Here: https://calspas.com/downloads/technical_bulletin/2012/Troubleshooting Guide for Acrylic Crazing.pdf Example photos of crazing here: http://multitechproducts.com/pages/Crazing.html#:~:text=Crazing appears as very small,the tightly coiled polymer chains.&text=Since styrene is a strong,crazing in an acrylic spa. 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 23, 2020 Report Share Posted June 23, 2020 That's crazing! 🤣 Gold star, Canadaguy!⭐ I am not sure if that's the problem, but nice bit of info. I would have never put a heat gun to acrylic for fear of bubbles and discoloration. I have repaired many with clearcoat with good results. 1 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 23, 2020 Report Share Posted June 23, 2020 I have never tried it either but seems simple enough. Was hoping he would give it a shot and post up the before and after the results. Will have at it on the next flip tub I get and go crazing on it. Magic eraser works great on scuff marks and light scratches as well. Works like magic 1 Quote Link to comment Share on other sites More sharing options...
jimmythegreek Posted June 24, 2020 Author Report Share Posted June 24, 2020 Thanx for the links. It's not crazing they are just swirls mostly. If it was I'd have the heat gun on it now that's a slick fix makes total sense. The 2 spots are wear spots long and skinny on a raised part of shell opposite the control pad both sides. Im guessing the cheap cover on it has a rough mesh backer under it that's been rubbing it on every slide off. RDspaguy I figured you were around these parts. They're lucky to have you here sharing the knowledge. When you say acrylic clearcoat are we talking about spraying on a new topcoat after some prep like blending clearcoat on a car paintjob? Enlighten me please 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 24, 2020 Report Share Posted June 24, 2020 Exactly. A little fine grit sanding and a spritz of clearcoat and you are good to go. I have even used clear fingernail polish in a pinch. Try the magic eraser first (works like magic😂). It can't hurt, and Canadaguy knows his stuff too. Quote Link to comment Share on other sites More sharing options...
ratchett Posted June 24, 2020 Report Share Posted June 24, 2020 13 hours ago, CanadianSpaTech said: Magic eraser works great on scuff marks and light scratches as well. Works like magic 6 hours ago, RDspaguy said: Try the magic eraser first (works like magic😂). It can't hurt, and Canadaguy knows his stuff too. Nowhere near as knowledgeable with HotTubs as these two guys, but I do work with plastics all day long for a living. If you don't suspect crazing, I would start with a micro-abrasive like melamine foam (aka Magic Eraser) - it's the safest and easiest way to start without causing damage to the shell I keep a box of generic melamine foam eraser pads around the home/office for all sorts of uses, I've even found them to work better than harsh chemicals sometimes depending on the surface. Just my $0.02 1 Quote Link to comment Share on other sites More sharing options...
