DKMin Posted June 11, 2020 Report Share Posted June 11, 2020 Hello, I follow Nitro's Dichlor then Bleach method. I am having an issue with PH drift and TA numbers however. First, I get CH to around 130-150, I then got TA to 80, Then, following his guide, I turned on all pumps and aeration and tested PH. Once PH drifted to around 8, I added muriatic acid to bring it back down to around 7.5 (I do a little at a time). I let it run another 30 minutes, tested again, added muriatic acid to bring it back down. By the time I got PH to stabilize from drifting (at 7.6), my TA tested low at around 40 which I am reading is unstable. If I add Baking Soda to get TA up again, won't PH drift be an issue once again? I'll be right back where I started I would think. Thanks Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 11, 2020 Report Share Posted June 11, 2020 The risk of low alkalinity is drastic ph drop. I would say stop aerating like a maniac and balance your water. If you get some aeration from use, deal with it as it comes. Ph up to 8.0 is ok. Quote Link to comment Share on other sites More sharing options...
DKMin Posted June 12, 2020 Author Report Share Posted June 12, 2020 Thanks, so should I raise TA back up? If so, to what? If I aerate when using the tub and get high PH drift, add acid, won't I eventually be in the same low TA boat? Thanks for helping! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 13, 2020 Report Share Posted June 13, 2020 Ph and alkalinity are opposite sides of the same coin, and one will always drag the other. Ph is a logarithmic scale while alkalinity is a straight ppm, so you see different amounts of change depending on where the readings are. Your water will seek (and find) it's own balance given time. What you need to worry about is ph, as that is what will bother your eyes and skin and damage your equipment. I suggest you stop worrying too much about your alkalinity and keep your ph in check. Quote Link to comment Share on other sites More sharing options...
DKMin Posted June 13, 2020 Author Report Share Posted June 13, 2020 Thank you, I will just use the tub and monitor PH and adjust accordingly. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 13, 2020 Report Share Posted June 13, 2020 👍 Quote Link to comment Share on other sites More sharing options...
DKMin Posted June 24, 2020 Author Report Share Posted June 24, 2020 Been using the tub and my PH is pretty much staying at 7.4 even with jets. Should I leave it alone even though TA is pretty low? Thanks again for the help Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 24, 2020 Report Share Posted June 24, 2020 Yes. Quote Link to comment Share on other sites More sharing options...
