Sprout Posted June 9, 2020 Report Share Posted June 9, 2020 Greetings pool gurus, Hoping to get some clues as to what's up with an older Jandy LXi heater that's not working consistently. Been in my house for about 5 years - pool and equipment came with the house, and was clearly a few years old at that point. Heater outdoors, but in a covered area so it's not getting rained on. Use the heater for integrated hot tub. Heater has been flaky the entire time we've been here - sometimes it would light, sometimes it wouldn't, sometimes it would come on once, but then not re-activate once the water temperature dropped - just flaky all around. Pool company we contracted with for service at the time could never make it work right; threw parts at it, called it "repaired", but the next time we'd go to use it (often weeks later), it would act up again. Most recently - wouldn't light at all, period. Checked resistance on the igniter; supposed to be between 40 & 75 ohms; was at 76 ohms one time, and 74 the next. Swapped it - seemed to help; lights the first time *consistently* now. Unit comes up to temperature, but will not re-ignite; ends up timing out after 3 tries, I get my ignition fault, and three flashes on the ignition control module. When this occurs, I *am* seeing the glow through the window on the side of the unit, so the igniter seems to be online. Replaced the flame sensor rod; it had a fair bit of residue on it - cleaned it first; no change, so swapped it. No change in behavior with the new sensor. Pressure sensor was replaced recently by my pool maintenance guy before I did the above - (he works for the old company, and has buddies who help with repairs) - it looks fine, both hoses are new - no obvious issues there. Would this be related to a fusible link issue, even though I'm consistently getting the ignition fault error message? Could it be the incoming airflow needs to be adjusted a bit, in that once the heater has been on for a while, the mixture needs to be slightly different to allow for the subsequent rounds of ignition and heating? I don't have the tools to measure the plenum pressure unfortunately. Open to any suggestions on what to check next; kind of a pain since I can't just do testing right off the bat - gotta let it heat up, cool down, and wait for that second attempt at heating. Unit is on propane, and has a dedicated line that's for it, a 900 square foot outbuilding, and a patio fireplace - neither of the others are in use when this occurs, and no issues with either of them. I'm stuck since the error is consistent, not pointing to other sources - appreciate any additional testing ideas or suggestions! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 9, 2020 Report Share Posted June 9, 2020 What parts have been replaced? Quote Link to comment Share on other sites More sharing options...
Sprout Posted June 9, 2020 Author Report Share Posted June 9, 2020 Shorter version: My pool guy recently (in the last couple of months) replaced the air pressure switch, respective hoses as noted, as well as a couple of temperature sensors (for an unrelated error I was getting - not sure of the exact part ID's, but right outside the heater). I replaced the igniter, and the flame sensor rod after the testing noted above within the last month. Since igniter replacement, unit consistently lights up and comes up to temperature on the first attempt. On three occasions that I've used it since, it does not re-ignite once the spa temperature drops below the set temperature. If I attempt to manually start it back up (turn spa off/on via the control panel at the heater), it flags an ignition failure (three LED flashes), although I do see the glow through the side window as it attempts to ignite beforehand. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 9, 2020 Report Share Posted June 9, 2020 https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.jandy.com/-/media/zodiac/global/downloads/l/l0747.pdf%3Fforce%3D1&ved=2ahUKEwj4vcCG7_PpAhU4SzABHUyxCNUQFjAIegQICBAB&usg=AOvVaw3_oqyi_NlRrHlJ4gFP7fYx Maybe this will help. Quote Link to comment Share on other sites More sharing options...
Sprout Posted June 9, 2020 Author Report Share Posted June 9, 2020 Thanks, but I have the LXi vs the LX, and this document seems aimed at the LX. I have the manual for the LXi otherwise which has a fair amount of guidance - just nothing that seems relevant to the symptom I’m having. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 9, 2020 Report Share Posted June 9, 2020 Ok. I would like to help but I don't have a great deal of gas heater experience, so I would just be guessing. Quote Link to comment Share on other sites More sharing options...
