minorhero Posted June 3, 2020 Report Share Posted June 3, 2020 Hello folks, Newbie hoping someone can help me out. My wife and I bought a house that came with a Lime Light Pulse Hot Tub. I am guessing its the 2010 model (or close to that year). Certainly the control panel is the same. When I finally got around to looking at the tub in the spring I realized pretty quickly it was not functioning (water leaks from one of the pumps, lots of corrosion etc). I bought replacement pumps for both jets, and for the circulation pump. Also bought a replacement heater (original was also leaking). I then installed all of this onto the hot tub. No leaks so I figured it was good and in fact the circulation pump and jet pumps work fine. My issue is the heater. It doesn't heat up at all. When going through the menu I notice the "summer mode" is turned on. For some reason I can not turn it off either. I can turn on and off the spa lock etc but not the summer mode. I am guessing this is why I can't get the hot tub to heat up. Is there a way to restore factory default settings? This is my hope for ways to fix it but I am VERY open to any other suggestions as I have hit a wall on this one. Simply turning the hot tub off at the breaker doesn't do it either. Thank you guys for any assistance. Quote Link to comment Share on other sites More sharing options...
castletonia Posted June 3, 2020 Report Share Posted June 3, 2020 Can you provide the serial number? I've never heard of that before but if you can provide the serial number so I know what year we are dealing with I can then ask Hot Spring what the options are. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 4, 2020 Report Share Posted June 4, 2020 To activate the Summer Mode, simply follow these steps: 1. Set the temperature control to 80°F (26°C). 2. On the control panel, simultaneously press and hold for three seconds Temp Plus and Temp Minus buttons to activate the Summer Timer. The Summer Mode must be deactivated when cooler temperatures return. To do this, simply repeat step 2. 1 Quote Link to comment Share on other sites More sharing options...
minorhero Posted June 8, 2020 Author Report Share Posted June 8, 2020 On 6/3/2020 at 6:59 PM, castletonia said: Can you provide the serial number? I've never heard of that before but if you can provide the serial number so I know what year we are dealing with I can then ask Hot Spring what the options are. PLS1N3068 On 6/4/2020 at 7:49 AM, CanadianSpaTech said: To activate the Summer Mode, simply follow these steps: 1. Set the temperature control to 80°F (26°C). 2. On the control panel, simultaneously press and hold for three seconds Temp Plus and Temp Minus buttons to activate the Summer Timer. The Summer Mode must be deactivated when cooler temperatures return. To do this, simply repeat step 2. Unfortunately this did not work. Tried several ways and for longer then 3 seconds but it never changed. Quote Link to comment Share on other sites More sharing options...
castletonia Posted June 9, 2020 Report Share Posted June 9, 2020 Serial number comes up as a 2011. I just emailed Hot Spring tech support and will reply once they respond. Quote Link to comment Share on other sites More sharing options...
castletonia Posted June 9, 2020 Report Share Posted June 9, 2020 From the 2011 owners manual. Quote Link to comment Share on other sites More sharing options...
Tremendes Posted March 19, 2023 Report Share Posted March 19, 2023 Has anyone figured this out? I have the exact same issue. Tried all the sequences with no luck Quote Link to comment Share on other sites More sharing options...
