Andrew88 Posted May 28, 2020 Report Share Posted May 28, 2020 Now typically I would use the forum search function first for a question like this, but for some reason, that feature on this forum refuses to load on my phone. Anyhoo, do spas typically consume water at any rate over a period of time?. Or, should the water level stay consistent at all times? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 29, 2020 Report Share Posted May 29, 2020 They lose water through carryout, evaporation, and leaks. Quote Link to comment Share on other sites More sharing options...
Andrew88 Posted May 29, 2020 Author Report Share Posted May 29, 2020 As I expected. If used daily and kept around 100 degrees F. Could that loss be around .5-1" daily or is that more likely suggestive of a leak? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 29, 2020 Report Share Posted May 29, 2020 That depends on how many people, how much clothing (shorts carryout more than bikini) and how long the cover is off. An inch a day is alot. I would remove the side and check the equipment for leaks. Sounds like a shaft seal or o-ring. Quote Link to comment Share on other sites More sharing options...
Cusser Posted May 29, 2020 Report Share Posted May 29, 2020 That's a substantial leak. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 29, 2020 Report Share Posted May 29, 2020 For me it's pretty normal, but I have a 7 year old who loves to splash and play for hours. Loss depends on use. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 29, 2020 Report Share Posted May 29, 2020 Is there a consistent wet spot/area around the base at one of the corners? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 29, 2020 Report Share Posted May 29, 2020 47 minutes ago, CanadianSpaTech said: Is there a consistent wet spot Keep your personal problems to yourself, pal.😏 1 Quote Link to comment Share on other sites More sharing options...
Oldy Posted June 4, 2020 Report Share Posted June 4, 2020 Do you heat it up? It can just evaporate that much over if you keep it toasty.. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 5, 2020 Report Share Posted June 5, 2020 That is very excessive for evaporation alone unless the cover is off for most of the day. Quote Link to comment Share on other sites More sharing options...
