Marios Posted May 25, 2020 Report Share Posted May 25, 2020 Hello I am new with pool chemistry. I have an infinity edge pool with a drop of 1.5 meters in a tank. I am adding sodium bisulphate, my ph drops and after 2 days it peaks. Any suggestions? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 25, 2020 Report Share Posted May 25, 2020 Aeration raises ph. Your water dropping that far could be the part of your issue. Can you turn off your overflow? What chemicals are you using? Quote Link to comment Share on other sites More sharing options...
Marios Posted May 25, 2020 Author Report Share Posted May 25, 2020 I can turn off my overflow. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 25, 2020 Report Share Posted May 25, 2020 Sodium dichlor is nearly half cyanuric acid (stabilizer) and will lock up your chlorine once over 50ppm making it unable to sanitize your water. I would recommend you use liquid chlorine once cya reaches 30ppm. Try turning off your overflow for a while and see if that helps. Quote Link to comment Share on other sites More sharing options...
Marios Posted May 25, 2020 Author Report Share Posted May 25, 2020 Thanks i will try and see Quote Link to comment Share on other sites More sharing options...
