Sodium dichlor is nearly half cyanuric acid (stabilizer) and will lock up your chlorine once over 50ppm making it unable to sanitize your water. I would recommend you use liquid chlorine once cya reaches 30ppm.
Try turning off your overflow for a while and see if that helps.
Link to post
