Blueser Posted May 22, 2020 Report Share Posted May 22, 2020 Good morning all, I am new to this site so please go easy on me lol. I also appreciate this has probably been asked a million times previously however I am going to ask the question until I get used to the search facilities etc I have a hot tub and whilst generally very happy with it, I seem to be struggling sometimes with balancing my ph and TA I check my water every day (a little OCD I appreciate) and as I say, I do have lovely clear water, however the ph and TA are sometimes a challenge and was wondering If I was missing something? My main issue is that my ph often reads slightly low on the test strip but the TA reads ok or towards the top end of the suggested test zone however when I add ph plus to my water, it seems to raise the TA too?? Is there a way that I can raise my ph without raising my TA? Please be gentle with me and try not to blow my brain with too much complicated science Thanks in advance Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 23, 2020 Report Share Posted May 23, 2020 Aeration will raise ph. Open the air control valves so you see white coming out of jets and run the pump for multiole cycles. Quote Link to comment Share on other sites More sharing options...
Blueser Posted May 23, 2020 Author Report Share Posted May 23, 2020 Thankyou mate I had a search around earlier and saw something similar so did this. The information suggested lowering the TA with ph minus until it was where it needed to be and then run the jets which I did and whilst the ph is not perfect, its withing the suggested zone on the test strip tub Thankyou for taking the time to get back to me Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 23, 2020 Report Share Posted May 23, 2020 I would recommend getting a test kit, strips are notoriously unreliable. Quote Link to comment Share on other sites More sharing options...
