LA Spas HEET Temp Control Buttons Not Working
The jumpers are just to the left of where you plug in the new topside under the round black cap. You will see 3 or 4 black tabs that will have 3 brass like pins but the tabs will only cover 2 of the pins...when they cover 2 say the left 2 they might turn something on if they cover the right 2 pins they might turn something off. Inside cover of the pack should have what the settings are but I don't see anything
  • Thanks 1
Link to post
Okay, I follow you. The schematic shows what the jumper settings are supposed to do. Is that going to be different now that I have an aftermarket topside? I guess its going to be a matter of trial and error to see if I can get the right configuration? I really appreciate the help by the way. Thanks very much. 942361138_InkedGeckoBoard_LI.thumb.jpg.439df46a5c215bad0103c77eecca33c1.jpg
Link to post
Okay, now this all makes sense. So this board will only work with either the TSC 44 or 19. Since I have 3 pumps, that means that only the TSC 44 will work. I'll have to return the K35 and order the right one. This should solve everything once and for all.
Link to post
