Allthewaymay 0 Posted May 7, 2020 Report Share Posted May 7, 2020 Hi bought a house very cheap because solar that heated pool on roof leaked causing a hole in roof. Now solar was removed and pool plumbing (Solar)capped off. So when I turn on my pump it works fine however when I go to hook up pool sweep in skimmer it does not move it’s almost as if the pump stops working also. I’ve checked for leaks on hose on lid at unions I’ve used a drain bladder at pump and skimmer. However there is a Jandy valve that is labeled solar on one side and pool the other when I turn valve to pool I hear a rush of water in pipes at pump I’m not used to hearing however it actually makes the pool sweep move. I’m not sure what this valve does nor can I figure anything out due to prior solar and my limited knowledge. Also why does my pool have 2 drains at the bottom? I will attach photos The black pipes are the ones I hear the rush of water. Thank you Quote Link to post Share on other sites
RDspaguy 629 Posted May 7, 2020 Report Share Posted May 7, 2020 If you capped off the solar then putting the valve in solar means there is no flow back to the pool. No flow means no suction means no cleaner. Keep it in pool position. Two drains are a safety feature. All pools are built that way now. Quote Link to post Share on other sites
Allthewaymay 0 Posted May 8, 2020 Author Report Share Posted May 8, 2020 IMG_0333.MOV IMG_0333.MOV Quote Link to post Share on other sites
Allthewaymay 0 Posted May 8, 2020 Author Report Share Posted May 8, 2020 61059459630__DFAE83AA-42CE-4DAA-9FBF-D7695FE69CF2.MOV Quote Link to post Share on other sites
RDspaguy 629 Posted May 8, 2020 Report Share Posted May 8, 2020 Your attachments are not available. Quote Link to post Share on other sites
RDspaguy 629 Posted January 31 Report Share Posted January 31 4 hours ago, AmeliaNorth said: It looks awesome, I have recently also bought a Kamado Big Joe 3, it's awesome and looks beautiful. I have read a lot of best grill cover reviews to look for the best grill and not a lot of money, but in the end, I understood that I am ready to pay a little bit more money, but buy something that will work properly without any problem for the next couple of years. I often like to cook steaks, burgers, hot dogs in my yard, and I more eat grilled food in the last 2 years after I had bought a house, so it like that I didn't save money and bought something very cool. What grill do you have at home? You do know this is a pool and spa forum, right? Quote Link to post Share on other sites
Pool Clown 10 Posted February 2 Report Share Posted February 2 If Alltheway comes back, tell him/her to close both of the blue handled valves and rotate the Compool valve 90 degrees clockwise (till the handle points to 9 oclock). That will give you all the flow back to the pool, and all the suction, barring a clean filter. Quote Link to post Share on other sites
