Hot Springs Circ pump noise + flashing red lights
HSFan
No problem. Humor best medicine๐Ÿ‘๐Ÿผ Well woke up and tub at 101 degrees, ready light on. Turn pump 1 on and ran for 20 mins. Turn both pumps on and been running for past 30 mins!๐Ÿ˜ Hopefully stays good all day and more! ๐Ÿคž
Thanks for all your expert guidance and patience getting me thru this!
Im back and you were right! ๐ŸคจGarage breaker blew 3 times since last message. (But enjoyed incident free tubbingย several times)ย I checked breaker visually and lookedย all ok. Going to replace breaker with Eaton 230250 quad $22. Picture shows breaker slightly popped. ย Will keep u posted.ย
  • Like 1
  • 7 months later...
The "limit ok" and "heaterย on" LEDs should be lit. If they are and the power and ready lights on the control aren't blinking then it is a bad relay board, heater, or tripped manual high limit if you have one.
Test for voltage to the heater at the board terminals. Do you have voltage?
Check heater for a reset button on the black box part of the heater. Often behind a rubber plug in the box.
Test heater for continuity.
ร—
ร—
