Adam cast Posted April 28, 2020 Report Share Posted April 28, 2020 Chemical issues Hi I have recently bought the lazy spa honolulu 920 litres. I set up day one added 3 tea spoons of dissolved stabalized chlorine granules and left for 24 hours. Tested water free chlorine level was 5, pH was low at 6.8 and total alkalinity was 80. I added 1 tea spoon of dissolved pH plus and tested 4 hours later. Everything was good so it was used heavily for the the rest of the day. Next morning I tested again pH OK, alkaline OK but chlorine free was down to about 1. I dissolved 2 teaspoons of chlorine and added to spa. left it for 4 hours retested and chlorine free level was down to 0. I left it for the rest of the day. Today I checked again and it still on 0.I am left in a dilemma as the test says to much chlorine can dye the test stick if level is over 15. The question is which end of the scale am I. Do I need to reduce the chlorine because its over 15 or higher chlorine because its 0. Thank you in advance I have a wife and 5 year who just want to get in it Quote Link to comment Share on other sites More sharing options...
dlleno Posted April 29, 2020 Report Share Posted April 29, 2020 the first think I would do is get a Taylor "drop wise" test kit. they are affordable, wonderfully accurate, and can a very wide range of levels. only then will you really begin to understand how your own water behaves and how much sanitizer you consume. test strips are notoriously inaccurate Quote Link to comment Share on other sites More sharing options...
