tagyerit Posted April 26, 2020 Report Share Posted April 26, 2020 May need to replace E-10 circ pump. Going to try flow switch first. It a 2010 J-365. Wondering if it’s best to stick to stock or if there is any replacement that might work better. ETA: This is the second circ in 10 years. Not to bad I know. Thanks Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 26, 2020 Report Share Posted April 26, 2020 For a pump that never turns off, 2 in 10 years is great. What usually does them in is the result of water chemistry or debris such as hair that slips past the filter. If you were replacing it more often I might suggest a different type, but those really wouldn't last much longer than you are getting from the Laing, and would require some plumbing work. If it ain't broke, don't fix it. Get the E10. Keep doing what you are doing, it can't be that bad or you'd be buying more of them. Quote Link to comment Share on other sites More sharing options...
bpkeeper Posted April 26, 2020 Report Share Posted April 26, 2020 Is your circ pump totally stopping or does it work intermittently? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 26, 2020 Report Share Posted April 26, 2020 Is the circ pump flowing water across the flow switch closing the toggle against the post? do you have flow from the circ pump going into the spa? What is the issue you are having. Do you have an error code showing? Quote Link to comment Share on other sites More sharing options...
