CanadianSpaTech Posted April 21, 2020 Report Share Posted April 21, 2020 Don't get many Hot Springs/Hot Spot calls in my area so looking for a little help on this one. The spa will start up run and heat to temp but once it gets there the pump won't stop running. Heat shuts off but pump continues to run. If I put the temp down a few degrees it will shut off as normal. Put it back up and it will run again. If the temp goes down on it's own to a lower set temp it will start the pump but not the heater and the pump will just run and run. If it is in the 10 minute "tranquility" mode and I activate the jets pump manually it will turn the heater on and heat. Filter cycles set correct no error codes showing. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 21, 2020 Report Share Posted April 21, 2020 Can't say I have seen a hot spot either. Is that a pressure switch with a blue wire wrapped around it, or are there multiple wires to that thing? This behavior is consistent, every time? Try turning off breaker for about 10 minutes and restart. See if it clears up for a bit. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 21, 2020 Author Report Share Posted April 21, 2020 Grey pressure switch on top... blue hi limit to the black thing beside. What should hi limit and temp ohm out at I was getting 8.3 on temp and 12.1 on hi limit but it was super cold out and exposed for a while so not sure reading was entirely accurate for hi limit. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 21, 2020 Report Share Posted April 21, 2020 That's a pretty big discrepancy, but I am not familiar with that control. Is it watkins? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 21, 2020 Report Share Posted April 21, 2020 This has a thermistor chart down the page for watkins, but if it's not watkins it may be different. Sensors should typically be within a few hundred ohms of each other, but that does not have to be the case, if that control manufacturer decided to use different rated thermistors for the different sensors. https://www.backyardplus.com/proddetail.php?prod=38416 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 21, 2020 Author Report Share Posted April 21, 2020 THX will have a look Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 21, 2020 Author Report Share Posted April 21, 2020 Going to throw a hand full of parts at it and see what sticks...lol. new sensor set Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 22, 2020 Report Share Posted April 22, 2020 That is strange behavior. Pump is sometimes controlled by temp, sometimes not. Heater will turn off but not back on. And that is consistent, not just what it did in the 15 minutes you had to spare on it? You got the same result multiple times? I wish I knew that system better. Those sensors were pretty far off, but that may be by design. Test the new sensors when you get them, I would like to know. Odd that bad sensors wouldn't throw an error. I guess you wouldn't be posting about a typical issue though, would you Jedi Spa Master? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 22, 2020 Author Report Share Posted April 22, 2020 Yes it's consistent behavior and agreed it's odd. Was able to find some ohm at temp charts for both high limit and temp sensors. Again very odd in that the temp sensor which controls the pump on/off was in range and the hi limit was the one that was high based on the chart. But there was discrepancy between the 2 and it's all I have to go on at this point. Unfortunately the sensors are not available through my local wholesale supplier so no discount/markup on the parts. I will test them before and after installing them and let you know results. Just hoping it's not going to cost this Jedi $100 to find out. Quote Link to comment Share on other sites More sharing options...
castletonia Posted April 22, 2020 Report Share Posted April 22, 2020 Wish I could help you on this one but the technical expertise required is well beyond my knowledge. That is not behavior I have personally seen, but our dealership doesn't see much in terms of service work on Hot Spots or Vacanza, the Caldera equivalent. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 22, 2020 Report Share Posted April 22, 2020 Vacanza? Now your just making up words. Snarfalicus! See, I can do that too. Berelmo! Plarmic! Hey, this is kinda fun! I get it now! Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 22, 2020 Author Report Share Posted April 22, 2020 Vacanza...I think I spent a night in jail there last time I was in Mexico. Dam you $2 Tequila sunrises Quote Link to comment Share on other sites More sharing options...
