JCH Posted December 22, 2019 Report Share Posted December 22, 2019 (edited) Hello I have 4 dashes however my water temp is 50 degrees so not high temp sensor....when I reset it will run for 40 minutes or so then back to four dashes. It hass done this before after a drain and refill after resetting several times it has gone away in the past...not today...suggestions? I am concerned as our weather is about to drop consistantly into the 20's over night. Edited December 22, 2019 by JCH forgot txt Quote Link to comment Share on other sites More sharing options...
castletonia Posted December 22, 2019 Report Share Posted December 22, 2019 Could be a pressure switch or circuit board. Try jumping the pressure switch and see if it starts heating. Quote Link to comment Share on other sites More sharing options...
Spa Board Doctor Posted January 12, 2020 Report Share Posted January 12, 2020 If you have "- - - -" on display and the spaside still responds to jet, light, temp button pushes there is a flow error. If you have "- - - -" on display and the spaside is unresponsive there is a high limit error. Low flow can cause either of these issues. Possible causes are dirty filter, weak or restricted circulation pump, bad flow sensor, or bad high limit. Remove your filter and see if the error goes away. If so, the filter needs to be cleaned or replaced. Cartridge filters should be cleaned monthly and replaced annually. Brandon@spokanespas.com Quote Link to comment Share on other sites More sharing options...
billnq0w Posted August 24, 2020 Report Share Posted August 24, 2020 So, I have this same issue I think. Getting two sets of dashes on my 2009 Caldera c45. All works ok, both pumps, and heating ok. But after jets are on for an hour or so, when it shuts off, it throws the dashes error code on the display. Another push on the pump buttons and all starts again fine. When I opened up the hot tub for a refill, I noticed a small leak under the control box. When i opened it up, there are small drips coming from what appears to be a pressure sensor on the heating unit. Could this be the cause of the error codes? If so, is it easy for a user to replace? It does not look to difficult?? Thanks for any help!!! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 25, 2020 Report Share Posted August 25, 2020 Yes, you can replace the pressure switch, it just screws in. It may be the cause of the problem. Do you have a multimeter? Quote Link to comment Share on other sites More sharing options...
billnq0w Posted August 25, 2020 Report Share Posted August 25, 2020 Thanks for the reply. Yes I have a multi meter. Not sure what I would be looking for? Can you help with that? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted August 27, 2020 Report Share Posted August 27, 2020 Turn off power, unplug sensors from board, take a resistance reading on each sensor with your meter on 20k ohm setting. Post results. With power off, take a resistance reading of the pressure switch. Post results. Post a pic of the equipment area and circuit board. Quote Link to comment Share on other sites More sharing options...
Countrygrl Posted May 25, 2021 Report Share Posted May 25, 2021 Hi, we just bought a house that came with a Caldera Palatino which I think is 2014 or older. We cleaned it and also flushed the jets, filled it, added bromine and started it. The next day the display was reading 105 degrees F so I adjusted the temp to 90 degrees. Halfway through the morning the display had 4 double dashes and was unresponsive to my attempts to change anything. The pump is working because I can turn the jets on all 4 settings. What am I missing? We are newbies btw Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 25, 2021 Report Share Posted May 25, 2021 Please start your own post Quote Link to comment Share on other sites More sharing options...
