Aquapure 1400 salt readings, seawater in pool
We have a saltwater pool with a Jandy Aquapure 1400 chlorine generator.  The Aquapure shows a salt concentration of 3300, and two pool companies show 3400 and 3600 using electronic salt testers.  A chemical test at one of the companies came up with 2600.  This pool is 60 ft from ocean water and I suspect hurricane irma blew a bunch of seawater into the pool awhile back.  My question is: would sea water skew the salt tests relative to a pool which contains only pure pool salt?  I am wondering if the additional minerals in sea salt might cause a higher reading on the electronic TDS salt measurements, Maybe I should drain and refill the pool, or perhaps recalibrate the Aquapure to compensate.  I am told the 2600ppm reading from the chemical test is the most accurate.
Thanks
  • 5 weeks later...
