FNSIII Posted November 21, 2019 Report Share Posted November 21, 2019 We took delivery on our Hot Spring Envoy salt water spa this week. Have only been able to use it once and today when I walk out an open the lid there is a yellow scum like substance arouthe edges. Our PH is sky high (9.0) and we have been adding one cap of Spa Guard PH reducer on the hour for 6 hours with little or no change to the water. What I am afraid of is starting a roller coaster effect of too high...too low...too high again. I didn't want to become a Chemist. I want a place to have a glass of wine and help take care of my back. Any suggestions are appreciated, Frank Quote Link to comment Share on other sites More sharing options...
Ahhsomeguy Posted November 22, 2019 Report Share Posted November 22, 2019 You need to do a plumbing and jet purge. That gunk can be easily removed and will,allow you to,enjoy clearer nd healthier water without all the fuss. Quote Link to comment Share on other sites More sharing options...
dlleno Posted December 11, 2019 Report Share Posted December 11, 2019 My hot springs grande was delivered contaminated with biofilms . This is something that both dealers and mfgs tend to dismiss but i can tell you that after a lot of experiments i concluded that the only solution was to purge and purge more than once in some cases. I recommend using the purge product known as "ahhsome" and i can say that because i have done the due diligence, tested numerius different products and dumped thousands of gallons of water in the ground in order to reach this conclusion Quote Link to comment Share on other sites More sharing options...
