wbr46797 Posted October 22, 2019 Report Share Posted October 22, 2019 (edited) So a few weeks ago I notice I had low water pressure and low flow in my pool, and usually I remove the de filters and just clean them and put them back and recharge...usually its low flow and high pressure...I also noticed a lot of bubbles coming from the returns so I figured I had a leak on suction side.. so I resealed my pump and the jandy valve and pressure tested suction line to skimmer.. ran the pump again and still low flow and bubbles from returns.. so then I tried to snake the suction line to see it was restricted (failure).. I finally took pump back apart and noticed a crack where the defuser oring seats so I bought a new pump and installed it and still have the same results.. im at a loss can anyboby help...I also did the dye test on all returns.. please help... thanks new jandy valve and plumbing as well Edited October 22, 2019 by wbr46797 not finished Quote Link to comment Share on other sites More sharing options...
brittanymarshel Posted December 8, 2019 Report Share Posted December 8, 2019 What's the size of your pool and after how many days the flow gets low? Quote Link to comment Share on other sites More sharing options...
