Tiger River Spa Posted October 19, 2019 Report Share Posted October 19, 2019 Hi Heater light is OFF on the main board inside the control box. Green light above it is ON. What does it mean? Heater is also not working and was just replaced. When plugged in, the circ pump runs for a minute and then shuts down. Main jet pump works fine. Quote Link to comment Share on other sites More sharing options...
Cusser Posted October 19, 2019 Report Share Posted October 19, 2019 Could the pressure sensor be telling you that your pressure is too low? Have you replaced the filter cartridge? Quote Link to comment Share on other sites More sharing options...
Tiger River Spa Posted October 19, 2019 Author Report Share Posted October 19, 2019 Hi thanks for the reply. I removed the filter while I work on it so I don't think that's it. The new heater came with both new sensor wires so they should be OK. Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted October 23, 2019 Report Share Posted October 23, 2019 Your circ pump should run 24/7 unless you are in summer timer. The heater light will be on when the spa is heating. If you do not have good flow, the spa will not heat. Quote Link to comment Share on other sites More sharing options...
