stape2000 Posted September 10, 2019 Report Share Posted September 10, 2019 Any help would be great. I have a Hot Springs Sovereign. Serial Number II3J1659. A few years ago we had lighting hit several things at our house and I assume the hot tub got hit as well. Over the last few months I have tried to figure it out and fix things. Started out I was getting no power to the main board. The heater relay is the newer type so that was obviously replaced some point before we bought the house with the hot tub. After lots of research I decided to buy a new main board. I installed it and now have power. After I flip the 20 and 30 amp breakers I get red and green flashing lights. Upon further research and the fact I was getting nothing from the circulation pump I decided to purchase a new one. I also purchased a new high limit and control thermistor. Last night I install all of these items. Turn the spa back on and the circulation pump now moves water as bubbles come out the bottom drain. Also the waterfall feature is moving water. The heater calls for heat and then quickly back to red and green flashing lights. I took apart everything after that. The heater tests fine at 10.3 ohms. I located the pressure switch inside the no fault heater and removed it. Could this be a pressure switch problem. I have everything taken apart and wish I would have tested the pressure switch before taking everything out. I would almost rather order the new 50 switch before installing just to take that out of the issue. Some other information. I am unable to control anything on the display board. 92 degress comes up with summer mode on. The jet button does not fire up the jets. Hopefully this makes some sense. Thanks again for any help. Quote Link to comment Share on other sites More sharing options...
Samoban Posted September 10, 2019 Report Share Posted September 10, 2019 Try removing the filters, turning off the spa from the subpanel (disconnect) and turning the spa back on. A lot of the times the Hot Springs series acts up is simply just a circulation issue, and it seems to me like your filters could be the cause. Quote Link to comment Share on other sites More sharing options...
stape2000 Posted September 10, 2019 Author Report Share Posted September 10, 2019 Well I did find out I have the jumpers JP 1, 3, 4 in the wrong spots with my new main board. Going to change those to the correct settings and try that. Can anyone verify if I should have the heater relay board set to 12v or 18v. My main board is new but not new enough to have the 12v and 18v options. Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted September 11, 2019 Report Share Posted September 11, 2019 The green and red blinking at the same time indicates the pressure switch. If you have good water flow from the circulation pump, you should contact your local dealer to replace your heater. Quote Link to comment Share on other sites More sharing options...
stape2000 Posted September 11, 2019 Author Report Share Posted September 11, 2019 Thanks. I actually figured it out. I did not have the jumpers in the correct locations. The green and red blinking light were not in unison but intermittent. Spa powered up fine...although now I have a broken valve I need to fix. Quote Link to comment Share on other sites More sharing options...
