cavmed Posted July 30, 2019 Report Share Posted July 30, 2019 I have a Leisure Bay hot tub that had a fried spa pack. I replaced the spa pack and controls 2 yrs ago with a Balboa VS510s. Unfortunately there has been a temperature sensor problem ever since. The jets/heater run almost all the time and the tub heats to 107 degrees, unless I leave the cover off. This is with the temp set to 80 degrees. I've tried shutting it down and restarting it many times and it doesn't work. I plan on installing a different topside control in case its just not communicating the temperature to the pack correctly. I think there must be a temp sensor at the heater as well, but it's built into the pack and I don't want to replace the whole pack again. I don't think there's a sensor in the tub itself. How should I approach this. The tub is barely usable and its running up my electric bill. Quote Link to comment Share on other sites More sharing options...
Loster Posted October 14, 2021 Report Share Posted October 14, 2021 Did you figure this out. I have the same control pack and heating problems Quote Link to comment Share on other sites More sharing options...
