Surveyor1951 Posted July 29, 2019 Report Share Posted July 29, 2019 I installed a new pump on my Softtub. I installed one of those blue plastic hydro heaters that clips to the pump. My original pump had the steel heater coil that goes around the whole pump. My circuit board worked fine before I installed the new pump. My new pump is the same model as my original one. My soft tub now runs for half hour & heats up for for about half hour the shuts down for about half hour then starts up again. While it is shut down for the half hour the jets will not run. I have the softtub set at 100 but the water temp is only 94. I installed the pump 2 weeks ago. Any ideas what the problem may be. Any ideas would be much appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
Mike R boston Posted October 11, 2021 Report Share Posted October 11, 2021 Did you ever find a solution. I have the same issue except mine doesnt really urn back on as far as im aware i have to unplug then plug back in after about an hour but then shuts off again Quote Link to comment Share on other sites More sharing options...
