Vinn Posted July 17, 2019 Report Share Posted July 17, 2019 I had a leak in the AquaFlo XP2 pump in my Morgan Oceanside Spa. The leak was between motor and the wet end. I ordered a seal kit from amazon and received it yesterday. I closed the slice valves and started to remove the pump, but a significant amount of water started draining and did not stop promptly, like the valves didn't close. So I drained the tub, removed motor and wet end, and separated the two. I found a great video on youtube from Spa Superman describing this process. The motor and pump are relatively new; only 2-3 years old, so everything came apart easily. The impeller was a little hard, but not too bad. I replaced the o-rings and shaft seals, no problem. I reinstalled everything back into the tub, filled it up, and powered it on. I didn't break anything during this process. All the plastic parts are intact. The whole process went very smoothly. The pump ran for 2-3 minutes, then I got a bright orange spark inside the motor. It tripped the breaker. There was no whine from the motor, and the pump was running in low speed. I flipped the breaker back on, and tried to start the motor, but all I get is a "click" sound when I press the pump button. I think the click is coming from the panel. Any ideas what went wrong? I am suspicious of one of the valves. When I opened it, the handle came off in my hand, and some water shot out in a stream. Could that be stuck closed, which would have constricted output from the pump? Like I said, there was no unusual or scary sound from the motor, and the pump was running in low speed. I see no obvious sign of anything being fried on the board, and the two buss fuses look fine. Quote Link to comment Share on other sites More sharing options...
Cusser Posted July 18, 2019 Report Share Posted July 18, 2019 4 hours ago, Vinn said: I closed the slice valves and started to remove the pump, but a significant amount of water started draining and did not stop promptly, like the valves didn't close. Any ideas what went wrong? I am suspicious of one of the valves. When I opened it, the handle came off in my hand, and some water shot out in a stream. Could that be stuck closed, which would have constricted output from the pump? I have such slice/knife valves on my own spa: yes, they suck, and didn't shut off well even when new. And I did have a handle come off like you did, and mine was stuck closed. M slice valves were assembled with 4 screws, so I bought a complete new slice valve at Ace Hardware and unscrewed the bad valve and screwed in the center part with handle of the new valve. So I didn't have to do any cutting/gluing in a very cramped space. Quote Link to comment Share on other sites More sharing options...
