Paul - Montreal Posted July 3, 2019 Report Share Posted July 3, 2019 Hi; This is the 3rd season we have had our spa (it came with the house when we moved in) and up until this year I have not had any problems at all. However, over the past month I have developed a really itch allergic reaction to something in the water - mostly on my chest, upper back, torso and a few spots on my legs. My Dr. told me to take a shower after the spa and use plenty of soap but it's not really helping much. We use the spa most days but I'm at the point of wondering if my spa days are over . For sanitation we have a UV unit which we replaced a couple of years ago and we used bromine pucks which are in a floating dispenser in the spa when we are not using it. We check the pH and the bromine level each day and adjust the flow through the bromine dispenser as necessary to keep the bromine level where it should be. Are there alternatives to Bromine that I should consider or could it be something else Any feedback at all would be great. Thanks Paul Quote Link to comment Share on other sites More sharing options...
clarity guy Posted July 4, 2019 Report Share Posted July 4, 2019 Had the same issue switched to H2O2 and clad I did way easier to use and it feels great my friends have used it now for 2 years they change the water once a year and everything is good Quote Link to comment Share on other sites More sharing options...
henryallen Posted March 26, 2020 Report Share Posted March 26, 2020 Is everything ok with the soap you're using? I know a lot of people are sensitive to it and can have allergic reactions. I prefer making my own soap, I usually order organic components at oilscenter online store. For example, I've recently ordered Soap & Melt Shea Butter, now waiting for the delivery. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 26, 2020 Report Share Posted March 26, 2020 There are many maintenance systems for spas. H2o2, hydrogen peroxide, is a great system used in hospital and sport therapy tubs and stainless steel tubs and swimspas. It is kinda expensive, has a significant investment in feeder system, causes a very high alkalinity, and uses dangerous chemicals. This is my recommended system that I also use in my own tub(s). My system for private spas, which I recommend to my customers and use in my own tub(s) is simple, inexpensive, and in my experience trouble free. Fill up Fill spa through filter inlet. Start spa and test pumps. Test water. Balance alkalinity to 100ppm. Wait at least 4 hours. Test water. Balance ph to 7.4-7.6 Add 4 tsp dichlor Wait 30 minutes. Test water. If total chlorine is higher than free chlorine, shock with 4 tsp dichlor. Wait 30 minutes. Test. Maintain After each use of the spa, add 1tsp plus 1/2 tsp per person in the spa of dichlor. Each week, test water and balance alk and ph as needed. Since dichlor is ph neutral you should not need to do much. If total chlorine is higher than free chlorine, shock with 4tsp dichlor. If you have ozone you will not need to shock. Each month, remove filter(s) and rinse with hose. Every 3 months, clean filter thoroughly. If using a filter cleaning solution be sure it is all completely rinsed from the filter fibers before re-installation. Every 6 months, drain and refill. Always leave cover open for 30 minutes after adding chemicals to prolong cover life. To avoid foam in your spa, do not wash your spa suit in detergent and fabric softener, rinse with plain water or just wear your birthday suit. Do not allow hair treated with product to contact water, wear hair up. Avoid suntan lotion, baby oil, and other skin care products prior to use. Do not get makeup in the water. Always rinse off before use. Avoid extra chemicals, scents, conditioners, clarifiers, borate, etc... They will only create problems and cause more frequent water changes. Mineral sticks, such as spa frog or nature2, are ok to use but un-necessary. You need: Chlorinating granules (99% dichlor) Ph increaser Alkalinity increaser Dry acid Test strips with free and total chlorine You may use: Filter cleaner Foam down This is my method. There are many methods of maintaining your spa, this is my preference. Others may advise you differently, that is their preference. What matters is finding a method that works for you. Try it out. You can always pour in a basketful of chemicals later if this does not work for you. Best of luck. Quote Link to comment Share on other sites More sharing options...
coolbreeze Posted April 21, 2020 Report Share Posted April 21, 2020 RDspaguy, I'd like to try your method but am wondering if i will run into problems if I have to be away for 2 or 3 weeks. I do have an ozonator. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 21, 2020 Report Share Posted April 21, 2020 That might be pushing things. You could get a floater for when you are out of town. Open it a penny's width with one tablet for each week you will be gone. Should be clean and safe when you get home. Quote Link to comment Share on other sites More sharing options...
coolbreeze Posted April 21, 2020 Report Share Posted April 21, 2020 Thanks, I appreciate your advice! Quote Link to comment Share on other sites More sharing options...
dlleno Posted April 23, 2020 Report Share Posted April 23, 2020 the one point that caught my attention in the OP was that there was a sudden onset of skin irritation. Have you purged this puppy? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 23, 2020 Report Share Posted April 23, 2020 53 minutes ago, dlleno said: the one point that caught my attention in the OP was that there was a sudden onset of skin irritation. Have you purged this puppy? Dlleno, this post has been double hijacked. The person we are talking to now is not the OP, or even the SP (second poster). Otherwise, I am right there with you. Quote Link to comment Share on other sites More sharing options...
dlleno Posted April 23, 2020 Report Share Posted April 23, 2020 oh wow thanks! Quote Link to comment Share on other sites More sharing options...
