nicakemp Posted May 27, 2019 Report Share Posted May 27, 2019 #1 Hi! I just tested my saltwater pool with the Complete FAS-DPD chlorine Taylor Kit and these are the results, water is still cloudy: CH: 200 Alkalinity: 130 PH: 7.4 FC: 0.5 ppm CC: 1.0 ppm CYA: less than 30 I'm still confused about the chlorine levels and should CYA be higher. I understand I need to SLAM the pool, but how much liquid chlorine do I add to raise my FC to what target level? I live in Michigan. 30K in ground Thanks for your help!! 30K, in-ground, salt water pool. Sta-rite filtration and heating system. SWG - Circu Pool si+ Quote Link to comment Share on other sites More sharing options...
Liam569 Posted May 28, 2019 Report Share Posted May 28, 2019 You can call your local swimming pools and clarify what kind of containment they have, so you can find out the information that is already being used in practice Quote Link to comment Share on other sites More sharing options...
