Avisk8 Posted April 19, 2019 Report Share Posted April 19, 2019 Was running g great for months but....My hot tub pump will turn on for a few seconds then off then repeats this process until the pump overheats. I replaced the capacitor and the same thing happens. I am not sure if it is the pump or the control board causing the problem. When the pump is running it only works on low speed (2 speed 240volt pump) when I push the jets button to get it into high speed it just turns off. Balboa vs500 Not sure on tub model...stickers were removed before I got it. Quote Link to comment Share on other sites More sharing options...
70_ragtop Posted August 11, 2019 Report Share Posted August 11, 2019 I have a similar issue..my pump Wil Humm / buzz then shut off (no breaker trips) it will do this repeatedly Sometimes it turns on and runs for a few seconds (sometimes for a few hours though way rarer) nothing is stuck When the motor buzzes I can turn the pump by hand and it will start (maintaining full low pump speed) for a second or two and shut off again. If I select the jets option (high speed) it does the exact same thing. It isn't blocked it's running then just stops and tries to start again. I don't see it being a start capacitor because I don't think that would let it just die when it is running. It does start on low speed by itsself about every 50 or 60 buzz/pause/buzz cycles. Quote Link to comment Share on other sites More sharing options...
plroweny Posted August 29, 2019 Report Share Posted August 29, 2019 My Solana jacuzzi trips the circuit breaker when the jets come on. Any suggestions on what would cause the problem? Quote Link to comment Share on other sites More sharing options...
Steve Broom Posted April 15, 2020 Report Share Posted April 15, 2020 i have a similar problem with my spa. Did you ever find the cause/cure ? On 8/12/2019 at 1:11 AM, 70_ragtop said: I have a similar issue..my pump Wil Humm / buzz then shut off (no breaker trips) it will do this repeatedly Sometimes it turns on and runs for a few seconds (sometimes for a few hours though way rarer) nothing is stuck When the motor buzzes I can turn the pump by hand and it will start (maintaining full low pump speed) for a second or two and shut off again. If I select the jets option (high speed) it does the exact same thing. It isn't blocked it's running then just stops and tries to start again. I don't see it being a start capacitor because I don't think that would let it just die when it is running. It does start on low speed by itsself about every 50 or 60 buzz/pause/buzz cycles. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 15, 2020 Report Share Posted April 15, 2020 Start a new thread Steve. Include what kind of spa you have, how old, any recent changes or repairs, and detailed description of your problem. Quote Link to comment Share on other sites More sharing options...
Dubs1954 Posted April 18, 2020 Report Share Posted April 18, 2020 On 4/15/2020 at 2:54 AM, Steve Broom said: i have a similar problem with my spa. Did you ever find the cause/cure ? i have the same problem. Has anyone diagnosed and repaired this yet? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 18, 2020 Report Share Posted April 18, 2020 Dubs, there are several different issues on this dead thread. As I suggested to Steve above, start a new thread. Include some basic information because all hot tubs are not the same. We will be happy to help if we have enough info to do so. Quote Link to comment Share on other sites More sharing options...
Ian J. Posted April 19, 2020 Report Share Posted April 19, 2020 I’m having same issue with my Emerald spa. I also changed the capacitor with no improvement. What next? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 19, 2020 Report Share Posted April 19, 2020 13 hours ago, RDspaguy said: Dubs, there are several different issues on this dead thread. As I suggested to Steve above, start a new thread. Include some basic information because all hot tubs are not the same. We will be happy to help if we have enough info to do so. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 19, 2020 Report Share Posted April 19, 2020 2 hours ago, CanadianSpaTech said: Right? If they can't even follow that simple advice there is no helping them anyway. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 19, 2020 Report Share Posted April 19, 2020 I'm not giving up Remove pump connection at the circuit board. Using a multi meter test for power coming off circuit board in low speed and high speeds. If you have correct voltage coming off the circuit board going to the pump in both speeds...Replace the pump Rd you still with me...any recommendations to add Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 19, 2020 Report Share Posted April 19, 2020 Ummmm, hmmmm, yeah, maybe START A NEW THREAD with some basic info about YOUR spa. Quote Link to comment Share on other sites More sharing options...
Frustraded2022 Posted April 26, 2022 Report Share Posted April 26, 2022 My jets turn off after 3 seconds then I hear a gurgling sound Quote Link to comment Share on other sites More sharing options...
kenny spa fixxer Posted June 30, 2022 Report Share Posted June 30, 2022 Hi. I have a 2018 Hot Springs (Hot Spot) Stride. 240V Singe pump with two speeds. I turn on the jets and it runs for about 45 seconds and stops for 4 minutes, then repeats this pattern. It does not trip the breaker. A few times I see the red light indicating the heater is on and I checked the voltage of 120 per leg. I have replaced the heater element since then, because a professional told me that was the problem. Not true. I also bench tested the motor with water flowing through it, and it ran 20 minutes with no problem. I just replaced the hi-limit sensor and the temperature sensor. I also tried jumping the pressure switch lines to bypass it. What else is there to check? Kenny Quote Link to comment Share on other sites More sharing options...
cranbiz Posted July 1, 2022 Report Share Posted July 1, 2022 17 hours ago, kenny spa fixxer said: Hi. I have a 2018 Hot Springs (Hot Spot) Stride. 240V Singe pump with two speeds. I turn on the jets and it runs for about 45 seconds and stops for 4 minutes, then repeats this pattern. It does not trip the breaker. A few times I see the red light indicating the heater is on and I checked the voltage of 120 per leg. I have replaced the heater element since then, because a professional told me that was the problem. Not true. I also bench tested the motor with water flowing through it, and it ran 20 minutes with no problem. I just replaced the hi-limit sensor and the temperature sensor. I also tried jumping the pressure switch lines to bypass it. What else is there to check? Kenny PLEASE start a new thread instead of bumping a several year old thread that is not related to YOUR spa. In that thread, include the info you provided here AND include pictures of the spa pack, the wiring diagram on the inside cover and of your equipment area. Quote Link to comment Share on other sites More sharing options...
