jpb35 Posted November 16, 2005 Report Share Posted November 16, 2005 I understand that Balboa locks its temperture so it will not go above 104 degrees. How do i get it to raise above that? Is there any way? I have been told that you can, but no one knows how to do it. Thanks, if you need to respond to my email for this thats fine. rapaz22@msn.com Thanks. Quote Link to comment Share on other sites More sharing options...
spa Dr. Posted November 16, 2005 Report Share Posted November 16, 2005 I understand that Balboa locks its temperture so it will not go above 104 degrees. How do i get it to raise above that? Is there any way? I have been told that you can, but no one knows how to do it. Thanks, if you need to respond to my email for this thats fine. rapaz22@msn.com there are all sorts of ways to overide the temp control unfortunatly most will void your warrantyor create a fire hazard. Its my understanding that prior to the 04 packs balboa would do it for you with a Rx from your Dr. they did however stop doing that in04. the best way I could recomend is to set your spa at 104 and set jet pump 1 for a 24 hour filter cycle this may create the "thermal creep" effect and give you a 3 or 4 degree increase. Fyi 104 is the industry "limit" to achieve a UL rating Quote Link to comment Share on other sites More sharing options...
